I'm looking for advice, and my lack of mechanical ability is going to show through here... I'm sending my ECU to Ivan to get flashed. He said that the V&H Fuel Pak I have is garbage and will not work with the flash (and can actually damage my my engine if I run it after the flash) and that I shouldn't use it. He said not to waste my money on replacing it with anything else and the flashed ECU will improve performance enough. My question is... what do I do with the Fuel Pak? Can I just take unplug it and not do anything else? Will the bike run without anything hooked up in it's place?
Thanks for your input.
Signed: Mechanically Challenged.
