Hi Dragstar,
I wish it was that simple, but it is not. Intake tract tuning is based on pressure pulses and valve timing. There is some pretty heavy math needed to do it right.
I won't write a book on this here, although it is complex enough that you could write a pretty long chapter.
Basicly, air is compressable, so the air within an intake track acts like a spring (actually more like the child's toy the Slinky). A properly tuned intake tract has a negative pressure pulse that is caused by the suction of the cylinder when the intake valve opens. This negative (less than ambient) pressure pulse travels (always at the speed of sound) to the open end of the intake tract (air filter or opening of the velocity stack) where it "bounces" back as a positive pressure pulse (greater than ambient).
Now the trick is to have the length of the tract cause that positive pressure pulse to be right at the back of the intake valve just before it closes after bottom dead center. The energy in the moving air pulse (actually enertia) then rams extra fuel/air charge into the cylinder, thereby greatly increasing the volumetric efficiency (VE) - which increaces power much like a turbo or supercharge does.
To make all this even more difficult, the air actually bounces back and forth several times within the intake tract while the intake valve is closed. We number these pulses because the air loses energy with each bounce. The pulse with the most energy is the 2nd pulse. It also requires the longest intake length to use. So you must determine what is the practical limit to intake length and pick the stongest pulse that you can use.
Next you must determine where you want max VE (power) in the powerband. The engine changes the velocity of the intake air as RPM changes. RPM is therefore varible, but the intake track is fixed (as in length and diameter). Generally, I try to tune for the middle of the RPM range. But in the case of the Warrior, I shoot for max VE at about 3000 RPM. You may want to go for more bottom or more top end, so it is for you to decide.
OK, for the math. To find a starting point for intake tract length for each air pulse, use the following: (the result will be the tract length in inches from the back of the intake valve, to whatever opening to outside air is used, and RPM will be your chosen powerband mid point):
2nd Pulse:
L = 132000 / RPM
3rd Pulse:
L = 97000 / RPM
4th Pulse:
L = 74000 / RPM
5th Pulse:
L = 54000 / RPM
You could go on, but after about 5 pulses, there really isn't much energy left to extract, so why bother.
Once you have the length, you then mock it up on a dyno and adjust the length with spacer blocks to obtain max VE. The math gets you to within an inch or two.
The plenum box under the fuel tank does all this also, but the uses both cylinder's pressure pulses to increase VE.
Hope this helps with your design.
Snake
