I've recently noticed that my front pads are rattling inside the caliper. I checked the pads out and there is plenty of material still on them. After speaking to a friend of mine,he suggested a few possibilities and he then noticed that my brake lever can be pulled all the way in until it touches the bar. Which hebelieves shouldn't happen.The bike stopseasily enough without the need to pull the lever all the way in. He believes the problem is that the front brake cylinder is not operating correctly.
I bought my bike brand new and although it's the 06 model with radial mounted brakes and braided lines (which is supposed to be better).I have never been overly impressed with the braking performance. My mate has a 05 and I believe his brakes were stronger. I suppose I just got used to it.
My questions are this :
1:Should the lever stop before touching the bar?
2
o you believe the master cylinder is faulty?
3:Can the cylinder be bought as a kit if it is faulty?
4:How easy is it to repair
5:Any other theories?
I'll beobliged if anyone can help. Tosh.
2
