Front Signals
1.5K views 11 replies 8 participants last post by  Dunkherron
Heres a better pic of the front turn signals.
Made brackets from 6061 aluminum .090 sheet metal.
The .090 works perfect because the gap in the fork clamp
is a few thousands wider than this.
Cut the sheet metal the same width as the fork clamp,
remove the 2 screws and slid it in the gap, mark for the screw
holes, remove the metal and drill the holes.
Slid back in gap, install screws and tighten. It will take just a
little more torque to close the gap to the metal.
Bend a 90 degree in the metal.
From this point you will get the idea.
I know these instructions are not very good, i'm not good with the keyboard. Anyone who would like better instructions by phone can PM me.
Hope the better pic helps.
Image Insert:
#12 ·
After installing the silver bullets on the front, the bike started
making clicking sounds and the tach light stayed on even with the switch off. I figured it was because I'm not pulling enough amps,
I dont have running lights with the silver bullets.
I thought that if I wired a light from the stock turn sig. to the running light wires it would fix the problem, it did but the bulb got
so hot I was afraid it would melt something inside the headlight.
So I took a small auto map light with a pen bulb and wired it in.
I figured it would fry the bulb but so far it works great, its very small and easy to tuck away inside the headlight housing.
Heres a pic of the rear lights.
Image Insert:
