If you are asking if the rear drybreak can also crack same as the side drybreak, the answer is probably yes because they are both old style on the 2002 model year. From these part numbers you'll see both male parts were upgraded in 2003.
Fuel Tank - Dry Break '02 - Underseat - Female 5PX-24305-00-00, Male 5PX-24304-10-00
Fuel Tank - Dry Break '02 - Left Side - Female 5PX-24305-00-00, Male 5PX-24304-00-00
Fuel Tank - Dry Break '03 -'08 - Underseat: Female 5PX-24305-00-00, Male 5PX-24304-11-00
Fuel Tank - Dry Break '03 -'08 - Left Side: Female 5PX-24305-00-00, Male 5PX-24304-01-00
You should be able to see the crack. Or a hose could have come loose. Or its a vent line issue. You'll have to trace the leak with the seat removedmaybe.
If this isn't what you mean, well, then . . .
fcwarrior said:
My bike started stinking up the garage and has left a couple of little leaks on the floor but it's under the rear break area. Does that have the same issue? Could be my fault in not replacing it correctly this last time around when I replaced the spark plugs.
