I commute 26 miles to work each day. Normally if my reserve light comes on at the beginning of the trip I still have no problem making it to work. The bike usually only takes 2.8 gallons after running on the reserve for 20 miles or more. Today the reserve light came on and the bike ran completely dry after 24 miles. I called a friend from work and he came with a can of gas. While I was pouring the gas in the tank we noticed gas dripping on the front cylinder head. There are two small hoses coming from the front of the tank that end just above the head. The first one has a check valve in the end and the second is just open. The second hose was dripping fuel. Now is the second hose the overflow and if so does it connect to the recessed cup in the top of the tank below the fuel cap? I know I didn't overfill the tank but some of the fuel from the can was dripping into the cup. Secondly is there a fuel filter in the tank under the seat and should it be cleaned after running dry? Does anyone else have a problem with the reserve light coming on very early at times and way too late at others?
As a side note 5 rice burners passed me by without stopping and 2 Harley riders came by and both stopped and asked if I needed help.
