1 - 5 of 5 Posts
Since storing my bike at the dealers over the winter, my Fuel Warning light has been coming on and staying on (intemittent). Even after fueling up it remains on(tank is full).
Sometimes it goes off and then comes back on, on its own... Weird I can't figure it out...
Any Ideas????? Help is much appreciated.. The dealer is not sure what is wrong.. All connectors appear to be in place
Recently I had the same problem. This winter I took my tank off to do BAK. After reassemble I noticed my Fuel Warning Light coming on intermittently.
I finally found one of the fuel quick connects wasn't firmly seated.
Good Luck.
One of the most common problems after storage or any work...take your seat off and disconnect the fuel dry break and then reconnect it. Make sure you hear the click. If that doesn't work there is another under the left side scoop. That is probably the problem...good luck
Just had my tank off and had the same problem. Turned out to be a small vacuum hose I hadn't reconnected. Check all those little black thingies.
1 - 5 of 5 Posts
