1 - 7 of 7 Posts
I was riding my 04 warrior down the road the other day and the fule light came on so I pulled in to get some gas and could only get one gallon in it before it was full. So the problem is the light wont go off is there a way to reset it??? Help!!
Make sure your dry breaks are tight, both of them. The fuel light should reset itself when the tank is full.
You have 2 dry breaks. One under the seat in front of the tank and the other is under the L side cover. Make sure they are seated properly. You might want to disconnect then reconnect. You will hear an audible click when they seat.
1 - 7 of 7 Posts
