1 - 7 of 7 Posts
I have a new Galfer SS brake line its 32 inches long with a small bend on one fitting for fitment see pics the line is silver and fittings platinum with clear shrink covering
Im thinking 50 is fair for such a quality line half what I paid for it
Is it shorter than the stock brake line? Mine is a bit long with my Yamaha risers and flat bar
I have four inch pull back risers and im going with a two line set up instead of one to two, so I had to go with longer lines for mine but screwed up and gave Galfer the wrong measurement and ended up with a line I cant use. I suggest you measure what you need center to center and see if mine will work
So this brake line goes from lever to the caliper in one piece?
yes but its part of a two line set up, it was short because of my 4 inch risers. It would work fine I believe on a stock set up I believe but better measure to make sure
1 - 7 of 7 Posts
