1 - 20 of 20 Posts
Slideshow presentation of a disassembled stock Warrior cap being assembled and my tools of choice.
I didn't remove the Spring Latch and 2-split roll pins that retain the cap & outer aluminum body or the small key interlock tab and fine spring. These parts are visible except for the fine spring which resides under the interlock tab.
The photos are undocumented
You might note that i identified the key cylinder radial position for easier assembly.
You can exit the slideshow at any time and review the photos in a higher resolution if you want. They were taken in macro mode and show lots of detail
I hope the enclosed will be a useful tool for some of your questions if you attempt this task
Gas Cap Components
Glad you decided to do this.........hope it answers everyones questions on how to work on the gas cap.[/emoticons/emotion-5.gif][/emoticons/emotion-2.gif]
quote:
Chris, thanks .... i wish you or 3youngns were here to show how easy it is to remove the 2-split roll pins [
][8D][
Many thanks Alan, as you know I am one of the knuckle heads that messed up his roll pins and then pm'ed for help.[:I] Maybe this will help others trying to mod there gas cap. [^]
Who started this whole polishing the gascap craze anyhow[?]
Very well done slide show. I am sure it will come in handy for quite a few people that deside to work on there caps.
I've had my chromie sittin on the shelf for a long time now because I know I will lose all that crap. Thanks for the slide show.
Alan, thank you for your How-to. Helped me today when I was putting my cap back together after polishing.[^]
But my life isn't that simple so as I was installing the cap on the tank I dropped the small set allen screw inside the tank[:0][/emoticons/emotion-6.gif!] I had thought about putting a rag in the hole[V] **** I learn evrything the hard way.
Took probably an hour to remove the tank, drain, remove front fuel line, finish draining, get screw to the hole, reach in with small needle nose pliers. What a dumbass I felt like. My son who was helping me found humor in it though.
All worked out in the end but could have been prevented by a simple rag.
2002 XV1700PC Warrior
I hope the enclosed will be a useful tool for some of your questions if you attempt this task [
Gas Cap Components
thank you "wiki-Alan"!
I can't see the slide show due to my phones operating system. :/
1 - 20 of 20 Posts
