1 - 11 of 11 Posts
I just installed my VBAK and then I went on my first ride since the install and my gas light now comes on a few seconds after I start my bike, and it wont go out, but the tank is full...any ideas???
You might find that the dry break at the rear of the tank is not clicked all the way in. I had the same problem once after removing the tank.
There are 2 dry breaks. First, remove the left side cover and just follow the gasline to a plast/metal thing directly on the exposed braket. Push on it and if it's loose you'll hear a click. Second, follow the ose on the other side of the bracket to the tank under the seat. Push down on that one. Again, if it's loose you'll hear a click. 90% of the time it's the dry breaks.
Worst case senario, you have a loose connection elsewhere in the fuel chain, when I picked my bike up, I drove 8 miles and the fuel light was on constantly, even with a full tank, this is the day it rolled off the dealership floor mind you, It took their "crack" service team 3 days to figure out it was a loose connection on the fuel pump. Needless to say Renton Motorcycles in Renton WA is not the place to have your bike serviced. I do everything myself now. Thanks to RSWARRIOR.com./emoticons/emotion-1.gif
[8D]
Dry break it was!!!!...rookie mistake...thanks a lot guys...once again this site comes to the rescue!!
1 - 11 of 11 Posts
