For comparison, by my measurements[/emoticons/emotion-4.gif], the stock bars have 5 inches of pullback, 9 inches of rise, and are 34 inches wide. By the Tucker Rocky catalog, definitions as follows;
RISE- Vertical dimension (height) of the bar measured from the bottom of the highest point on the bar (viewed from the side with the front face of the bar positioned vertically).
PULLBACK- Horizontal dimension from the front face of the bar to the rearmost point on the bar. Measured in a front to rear direction (viewed from the side with the front face of the bar positioned vertically).
Being 5'8", I need a bar that comes back farther than stock so I am not bent over reaching for the bars to be comfortable and a little bit narrower than stock.
THIS IS HOW I DETERMINED MY PREFERENCE ON THE BIKE-With the bike sitting upright on a stand, I removed the bars and sat on the bike in my desired riding position (back straight,elbows slightly bent, etc.). I then had some help measuring the dimensions from the handlebar clamps that would hold the center of the bars. We measured the horizontal dimension to get pullback, the vertical dimension to determine rise, (both measured to the center of an imaginary straight bar that I was holding- but remember in the horizontal and vertical plane!!!) and the distance at the outside of my hands determined the width. I am using a HD bar that has 7 inches pullback, 2.5 inches rise, and is 32 inches wide with a 6 inch curved riser. Not only does it look good (reflects the radius of the front of the tank) it puts me in a comfortable position with my elbows bent. Once you have dimensions, you can look at varoius manufacturers to find a bar that meets your measurements or is close. But there is not substitute for trying them out!
P.S. I do not know if stock controls and cables would work on this bar as I am using aftermarket controls as well. But I hope this helps.[/emoticons/emotion-2.gif]
Andrew Preston
