1 - 2 of 2 Posts
I ordered some urethane golden tight bushings for my 02 Warrior and was actually looking for a video to walk me through the process so I don't mess anything up but am unable to find one. Does anybody know of a source that has a video walking me through it? If not any info would be greatly appreciated. I'm just trying to replace them because they are all rusted up and don't look all that great. Thanks in advance guys
No DIY or Video for the R&R but this link has some useful info:
I would suggest you remove the Top Triple Tree for the R&R of the OEM bushings unless of course you have the proper spacers and set-up to pull the bushings out using threaded rod as done here with the steering stem. Shown as Example ONLY!
The OEM tree bushings are thin wall 30mm OD steel tubing so you'll need a close fitting (slightly smaller OD) round improvised tool to press or pull them out. Pressing on the heavy wall inner tube will only tear the urethane/rubber isolator.
1 - 2 of 2 Posts
