Billy's bars are top notch!! I can vouch for his work because I have his double dagger "Z" bars chromed and custom fit to my warrior. I am totally satisfied w/ the look and the pull back on mine. I get 13" pull back w/ about 8-9" rise w/ my bar & riser setup. I chromed it here in San Jose, CA for a lot less than Billy's site but my bar's pointy ends required more touch ups at the chrome shop and several layers of chrome to get it right.
There are some benefits to buying his bars: first it's the "custom" part, which will make sure it will fit and second, it's the quality of his work. Personally though, I needed the bars to be made w/ something heavier than aluminum since almost all aftermarket bars are made w/ aluminum and they were vibrating like **** on my bike. I've tried several things to reduce the vibration on my previous Yami T-bar and although I'd succeeded in "reducing" some vibration, it wasn't to my satisfaction. Hence, I was looking for an alternate material to create the same bars when I came across Billy's bars. Billy's bars are all made w/ steel pipes which is considerably heavier than regular aluminum bars. They vibrate less and that annoying "tiny" vibration that made my hand numb after a while was completely gone. Billy's bars were heavy and solid yet light enough to be on the risers and stay on.
If anyone is looking to reduce vibrations on their bars, Billy's bars will do the job. Plus, you can "customize" to your liking so it beats installing all other aftermarket bars for that purpose. You guys are welcome to take a look at my gallery!
