Arizona Warrior said:
The question is, doing the math, what do you really gain in the real world. It doesn't take much distance to increase compression but there's often other factors affecting HP gains to the rear wheel.
Churchkey said:
Its an old school mod that still works.
After head milling or installing a thinner head gasket there are several other issues that need to be addressed.
If the cylinders share an intake manifold the manifold to head mounting flanges will need to be machined. With a "V" design engine moving the heads closer to the crank centerline decreases the distance between the intake ports. This is not a concern if the engine uses individual intake manifolds.
The exhaust system is normally not a problem.
The most important concern is rocker arm geometry, push rod length & hydraulic lifter design. Do the hydraulic lifters have enough working room to live with the pushrod cup (using the above specs) .040 deeper in the lifter chamber? I would have to have adjustable push rods to get the lifters back to factory specs. Adjustable rockers are not the answer as the fulcrum point changes & the relationship between the rocker arm & valve stem changes. The motor will run howver valve guide wear will be increased.
Also:
If the lifter cup can handleliving .040 deeper in the lifter borethere may be a problem at the high end of the rpm scale. If the lifters pump up & create valve float they will move the push rod end of the rocker arm .040 higher than normal valve float. Add to that the rocker arm ratio & lets use 1.5 as an average, the valve is now .060 closer to the piston. Add the .040 for the thinner head gasket & the valve is now .100 closer to the piston during valve float. This could have disasterous results but is dependent on combustion chamber design, piston design, factory valve to piston clearance & camshaft profile.
In conclusion: There is a bit more to this mod than just installing thinner head gaskets to increase compression.
