I recently installed 108 kit and 42mm throttle bodies. Got lots of low end torque (120 lbs at 2500 rpm) but bike over heats when stuck in traffic for long periods (5 minutes waiting to get thru light). This causes detonation when bliping throttle at idle or on hot start. No detonation occurs at higher rpm only at startup. One solution would be to take some timing out at low rpm but I'm not sure if there is box available. Another posibility is going to hotter cam but this will kill low end torque. Any ideas would be appreciated. Thanks cbs.
