1 - 3 of 3 Posts
Here's my problem guys.
I rode the bike for the first time in about 2 months today andI put fuel stabilzer in the tank before I left. Today the bike sat at idle immediately after startup and sounded great as usual. I rode it around for about 15 minutes with maybe 1 or two stops. As I am getting off the highway I came to a light and the bike stalled once I came to a stop and put it in neutral to stop. I looked down and it was about time for some gas so I went to the Hess station and filled up, only about 2.5 gallons and on my way I went. At every stop from there out it stalled. The idle was extrememly low and varied. I let it sit at home for a couple hours and when I started it again it sounded good and idled fine but had a slight sucking or gushy sound. I racked the throttle a quick second and it stopped making the sound and started idleing fine again.
Before I take the tank off and try to find the noise do you gys have any ideas?
Thanks in advance for the help as usual.
Roger
My brothers bike sounded like that, it's not a Warrior but I put my hand over each exhaust pipe and one was not firing, we found a small metal shaving in a float from a previous mod. I know the Warrior is not the same but maybe a place to start? One cylinder not firing?
The fuel stabilizer needed to be added before it sat in cold temps for 2 months. My guess is you had some condensation in the tank. Once you get into that new tank of gas a bit it should go away.
1 - 3 of 3 Posts
