Sorry...that was a typo...the WHEEL CENTERLINE appears to be about 3/4"-1" shifted to the left. Under the fender, with some adjustments to the axle adjusters, there is over 1/4" - 1/2" clearance on the right, and 1/8"-no clearance on the left - because the fender goes from 13" wide at the curve to 12.25" at the rear, the fender actually 'closes in' on the wheel the further you move back, so the clearance up front is minimal, and non-existent in the back....that is why the wheel can be shifted WAY off center, and you still have a minimal clearance difference at different points on the tire.
Sam at Broward is the best - he actually called me from Daytona (raining miserably by the way) at 7:30am this morning to walk me through the bike...and mid-way through the conversation, there was a "what did you say?". I am using the stock fender and STOCK struts, which are designed to line up the rear fender over the STOCK tire. When you widen the rear tire, you widen the right side minimally, while the left side gets the majority of the added material (unless I am mistaken, but I can see some small pitting through the chrome where the welds were, so this gives me the weld width). Again, the Physics kick in, the wider you make the left side, the more the centerline will move to the left by a factor of 1/2. Widen the wheel 2", the center line moves 1" in that direction since the centerline of the tire is 1/2 the total width and you added 2" to one side.
The result is that my wheel and arm are where they are supposed to be, but my fender didn't get shifted. These kits normally take a new fender with new struts to recenter the fender over the wheel. With the 280 kits, this isn't an issue because the arm actually goes into a jig and you recenter the wheel by moving the actually arms on the swing arm.
So I will move it with spacers and washers, and worry about it later. It still looks bitchin' and you really can't tell unless you are staring down the rear end of the bike and mentally lining everything up.
