1 - 9 of 9 Posts
There is a big hex, allen type bolt to remove the front wheel axle, what size is it and where do I get a hex that big?
A cheap and easy tool is find a bolt with a 3/4" head and double nut it, it fit's perfect inside the axle. The double nut is so you can use a socket to loosen and tighten the axle, I made one a long time ago for all my MX bikes.
i bought a 3/4 inch impact socket @ my local industrial tool supplies for $12. the right tool for the job is always better the rigging something up.
The pinch bolt is located behind the plastic fork guard on the lower right fork. As for the axle all of the above works good.
Best answer... EVAR!!! [}/emoticons/emotion-1.gif][/emoticons/emotion-4.gif][/emoticons/emotion-2.gif][8D]
1 - 9 of 9 Posts
