Help With Electrics
982 views 12 replies 7 participants last post by  amospro
I need some help please. I've just been fitting my Legends Forward Controls and had to relocate the horn and re-wire the rear brake light switch. For some strange reason now nothing is working at all!! No lights/horn/turn signals and so on yet my ignition is still wotking and the bike still starts. I have checked all of the fuses under the seat and everything appears to be fine.
Anyone any idea where I should check next? Anyone experienced the same problem before? Most grateful for any help/direction.
#8 ·
I doubt very much that the Horn has anything to do with the circuit pertaining to what you mentioned. My educated guess will bring me back to the rear tail light where you had to re-wire. Wire's are either crossed or not properly grounded or pinched, frayed leads groundeing themselves out etc. Did you forget to plug in any of the connector's? The problem lies where you moved or rerouted those wires or re-wired them.
#10 ·
Fixed it. Like you said, I went over every single wire inch by inch until I came to the left side horn location where there was some pretty loose looking wires. Euro Spec bikes don't have two horns, we just have the front horn so I decided to relocate to where you guys have your second horn. Wires were touching and obviously had a bad connection. All is now well and I thank all of you Gentlemen for your advice and assistance.
