Would someone with a 2004 or newer Service Manual please look up the published torque for these fasteners?
In the 2002 Service Manual the torque valuesstart onPage 2-20. That may vary in newer manuals. Part names:
Clutch Boss
Middle Drive Gear
Rear Wheel Sprocket and Drive Hub
Swing Arm Pivot Shaft
Front Wheel Axle
Rear Wheel Axle
Brake Disc and wheel
Valve Lifter Case
Handlebar Holder - Lower (riser)
I recognize the torque values in the 2002 manual for a couple of theseitems mayhave been printed incorrectly and like many members I've made those notes in my copy of the manual. I'm interested to learn if Yamaha corrected the Service Manual in future years. I'm also interested to learn if the torque values for the other items may have changed from the 2002 manual.
Once corrected by Yamaha its unlikely thetorque values wouldchange again
but in case they did, such as somedesign change requiring a torque value change,please also indicate what year service manual the torque values arefrom. Thanks.
Clutch Boss
Middle Drive Gear
Front Wheel Axle
Rear Wheel Axle
Valve Lifter Case
