1 - 2 of 2 Posts
I was wondering what the charge to do the hidden caliper mod.I read some one say like about 400 .00 total. is this about the cost total to cut the tab off the caliper and weld it on the other side and drill and tap a hole on the bottom of swing arm .I was just wondering if i was missing any of the details i was thinking of doing this to my extra stock arm before i sell it or if i need to send it out .Thanks
if you use the existing mounting hole on the top of the swingarm, instead of making a new one on the bottom, you should be able to do it for less than $100. drilling and tapping shouldnt set you back much. 1/5-1 hr labor. I would guess mounting it on top is stronger than mounting it on the bottom since on the bottom, the rotation is trying to pull the bracket away from the swingarm instead of pushing it against it, but i'm going to mount mine under. the whole point is to I use much more front anyway.
1 - 2 of 2 Posts
