hide heatshield clamps on bigshots
1.1K views 11 replies 7 participants last post by  audio77
Hi, i put a new set of v&h bigshots on my warrior. i was wondering if any one had a trick to hide the heat shield (hose), clamps? it seems any where i put them, you can still see them. The only thing i can think of is to pull them back off, after you have them set strait, and tightened. then tack weld the clamps on either side, (to hold them tight), cut off the nut, and finish weld. i'm not sure if hose clamps will take a weld? any ideas? also, i had hard chrome big straits on my old vstar, and liked them much better, (sound, & especially, fit & finish). wish i would have got hard chromes instead. any one want to swap hardchrome straits for bigshots? thankyou for your help.
#5 ·
i angled them down, but if your standing back you can see the two in the rear, in between the pipes. the top are facing up, the bottem are down. just the two in the rear on the top pipe really stick out. do you know if you can get different baffles for these? thankyou for your help.
#7 ·
has anybody ever heard the quiet baffles? it wasn't so much loudness, i don't like, i think the rolled ends muffle it. doesn't seem to have a crisp, clear, note to it. more like running straight off the header. also, all the way down the top of the top pipe it has small dimples, either from welding hold downs, or, forming. not at all impressed. I will probably try to sell these, and buy a set of hard chrome 3' big straight's.
#8 ·
