imevh2 said:Haven't done much searching yet but thought I'd ask, is therea good place to get hollow bolts for doing an internal wire job or am I better off just buying some hardened ones and having them machined?
Practically speaking, the Warrior OEM handlebar wiring uses multi terminal Hitachi style connectors that would not be suitable for your desired modification. Removal of the riser bolt would require extracting the terminal pins from the connector body to remove the handlebar.imevh2 said:Haven't done much searching yet but thought I'd ask, is therea good place to get hollow bolts for doing an internal wire job or am I better off just buying some hardened ones and having them machined?
