1 - 10 of 10 Posts
I am looking for what would be the no mods straight off the show room floor factor spec(?) for a 02' warrior. I had mine dyno'ed this weekend and I have added a V&H Propipe and a power commander and need a comparison. Any info would be helpful.
I don't mean to be rude bro....but SEARCH this forum. There are a ton of specs posted. Do a search for tourque or horsepower, or dyno all should bring up some good info for you!! Also you will find via search the acutal owners manual for the 02 which will provide the off the show room floor specs. Search bro....Search!!!!
Motorcyclist online shows the numbers for almost all bikes...
Warrior - 76.3 @ 4500 HP, 97.9 @ 3500 Lbs TQ
http://www.motorcyclistonline.com/performancedata/
that's a good page to bookmark - thanx Wes!
+1 Thanks for the link.
HP for stock bikes has varied a good bit around here. It seems like most are in the mid to upper 70's, with others being closer to 85. Torque seems to be less varied at somewhere around 100 ft-lbs.
Mine dynoed 84.5 hp and 112 ft-lbs with 110" HC pistons and churchkey's vbak.
quote:don't mean to be rude bro....but SEARCH this forum. There are a ton of specs posted. Do a search for tourque or horsepower, or dyno all should bring up some good info for you!! Also you will find via search the acutal owners manual for the 02 which will provide the off the show room floor specs. Search bro....Search!!!!
Let's be real. Try searching any one of the "keywords" you mention. Torque brought up 1800 different threads. It would take about 3 days to get through it all. Maybe instead of just saying to search, you could offer a link to a thread that might offer an answer.
ridingrules - what kind of exhaust did you have on when you dynoed at those numbers?
quote:Originally posted by ridingrules
....Mine dynoed 84.5 hp and 112 ft-lbs with 110" HC pistons and churchkey's vbak.
Thanx for that page Wes that is gonna come in handy!! Good stuff! And I agree with Bore Pig, We are here to help each other out! By one person asking this question Wes has helped 3 people so far... its the way it goes man.
1 - 10 of 10 Posts
