1 - 11 of 11 Posts
Picking up my new to me 2005 warrior next week. According to NHTSA all recalls have been done. But how can I find out if all the other fun stuff has been done like the 5th gear?
Well, you could report here precisely what your 5th gear rpm is at steady 60mph and one of the guys who did that mod will chime-in. Else do a search for that mod and in most threads discussing this someone mentions it.
For other mods, if its external you can post pics of areas and folks will help. If its internal like HC pistons you can check compression but the compression release needs to be fiddled-with; or look into one spark plug hole with a light in the other and you might get lucky.
Ok so speedo at steady 60mph the tach is 2200-2300 rpm. And I’ve attached all the pics... I don’t think much else has been done but I feel like the 5th gear might have been it feels like there’s more 5th than I remember.... still begging for a 6th but not as bad.
You got an air horn as well as well as a Corbin seat,
Nice clean bike.
Yeah I’m really happy with the Corbin seat and big shots. First two things I would’ve done, saved me a ton of money. The air horn looks cool and sounds cooler, def digging that too!
Need a GPS to verify actual bike speed the relationship between the tach & speedo does not change using the Roadie 5th gear. Also: If the drive pulley or tire size has been changed actual bike speed is effected.
Luck with your new ride.
1 - 11 of 11 Posts
