Bump to top.
I only noticed the smell of fuel when parked in the garage, then noticed the slowly expanding puddle under the bike. It really seemed like the sleeve that the fuel line mounts to, just came loose. I don't know if those are friction fit, or suppose to be welded etc. but given what seems to be the quantity of issues, and the potential impact the defect causes, it should be a considered a serious issue.Seems like enough have popped off at the elbow that there should be a recall. It's dangerous as ****. Matt Seaworth had his burn down from that se elbow leaking. Had it happen on my.old Warrior, but I was only a couple blocks in so the motor wasn't hot yet.
Long-time lurker, first time poster (really thought I had posted before, but my emails showed nothing, so oh well). Bought my '02 Warrior in... I wanna say 2016 with the left dry-break leaking. Had 9k miles. So had that replaced right off. Now it's got 28k miles and noticed another gas leak. I could be crazy, but it appeared to be just leaking from the right side (high side when on the stand) fuel line. The dry-break under the seat looked fine and the other line that snaps in with the fitting looked fine too. It seemed the metal clamps on the ends of the lines were failing. Is that possible?
Attached pic shows in red where I believe the leak was coming from (line detached now, clearly), and blue shows where it was pooling (low side when on stand).
View attachment 249495 View attachment 249495
The nipple on the end of the fuel line pictured comes loose from the housing, judging by the fuel stain I'd bet this is your problem.Well looks like I have a fuel leak somewhere. I read in the thread there was a recall so going to search for that's and see if I have it done.
07 14k miles
Not sure exactly where it is leaking yet. Need to pull the tank. View attachment 250246
