Cleaned it off and checked again this morning after riding yesterday (didn't know it was leaking). I have an almost full tank. Can I flip the tank safely to work on this? Or need to burn some gas up?
Cleaned it off and checked again this morning after riding yesterday (didn't know it was leaking). I have an almost full tank. Can I flip the tank safely to work on this? Or need to burn some gas up?The nipple on the end of the fuel line picture come loose from the housing, this may be where your leak is from.
Thanks Arizona! Read the whole thing and it's scary how easy this was to push back in. Secured it with zip ties and going to ride around until the gas tank is empty and check for leaks. Either use jb weld or just purchase a new piece.That aluminum fitting that attaches to the tank uses a press-fit connector that is known to come loose. Check through this thread for pics by other members and you will find a match and will know where to look and what to do. I know its a long thread but its worth the time.
i think that was common in the earlier warriors. luckily its a pretty easy fix. be safe and dont catch on fire.2002
Gas dry break on left side of engine now leaking
Can that be bypassed for short term? Parts are on back order and leak is real bad nowi think that was common in the earlier warriors. luckily its a pretty easy fix. be safe and dont catch on fire.
It can but not recommended as there's not a great way to take the tank off if there is any fuel in it at all. There is an aftermarket solution that many, many owners have undertaken where the dry break on the left side is completely replaced.Can that be bypassed for short term? Parts are on back order and leak is real bad now
Only need it temporarily, as I have the parts on order.It can but not recommended as there's not a great way to take the tank off if there is any fuel in it at all. There is an aftermarket solution that many, many owners have undertaken where the dry break on the left side is completely replaced.
Check this thread for a parts list and some details:
Left side cleanup kit INSTALLATION
For those of you who participated in the group buy, this thread will hopefully serve as your instructions. Two important things to note before beginning: Even if your main fuel tank is empty, you will spill gasoline when you pull apart the fuel pressure regulator. Please make sure that your...www.rswarrior.com
@Scot1700 .. this component appears to be available new on ebay & Dealers! If replacing this part, you'll want too also replace the contoured 2-hole gasket and (2) Flat sealing washers if available.My 02 (25k miles) just started leaking fuel a few weeks ago, about the same time she started hesitating when taking off or cruising at lower speeds. Noticed fuel coming from the fuel filter assembly (not dripping). The nipple was coming out of the assembly and had to push it back in while driving.
I want to order a new one but no one online. I don't trust a used one, just want to fix the old one but not sure how yet.
