Everything I find says the sealed lead acid (SLA) and gel are the same chemistry, both are sealed lead acid, and both use the same charger EXCEPT the gel battery cannot be quick-charged it can only be trickle-charged because there are no vents for gasses.
Example:
http://answers.yahoo.com/question/index?qid=20080617085141AARMdlh
Question: "What is the differencebetween gel & acid Batteries other than if you pouch them over the gel will not leek or is there different chargers for these batteries."
Answer 1: "A gel battery (also known as a "gel cell") is a rechargeable valve regulated lead-acid battery with a gelified electrolyte. Unlike a traditional wet-cell lead-acid battery, these batteries do not need to be kept upright (though they cannot be charged inverted). In addition, gel batteries virtually eliminate the electrolyte evaporation, spillage (and subsequent corrosion issues) common to the wet-cell battery, and boast greater resistance to extreme temperatures, shock, and vibration. As a result, they are primarily used in automobiles, boats, aircraft, and other motorized vehicles. These batteries are often colloquially referred to as sealed lead-acid (SLA) batteries due to their non-leaking containers, but they are not completely sealed; the valve regulation system allows for gas to be expelled. Chemically they are the same as wet (non sealed) batteries except that the antimony in the lead plates is replaced by calcium. This preserves the mechanical characteristics but renders the construction far less prone to gassing. The battery type is often referred to as a Lead-Calcium battery.
At high currents, electrolysis of water occurs, expelling Hydrogen and Oxygen gas through the battery's valves. Care must be taken to prevent short circuits and rapid charging. Charging with a constant voltage (called the float charge voltage; 2.26 V per cell for a lead-acid chemistry) can cause a rapid initial current, so therefore it is suggested to begin with a constant current, using constant voltage only for the final portion of the charging. However, the float charge voltage should not be exceeded by much for typical usage, so the switch between the two modes typically occurs when the float voltage is needed to sustain the charging current through the battery's internal resistance (as per Ohm's Law). The easiest way to implement this is to use a constant voltage device with a current limiter."
Answer 2: "Gel batteries are designed so they wont leak and they can be used anyway up. Because of this they are sealed which means they have a catalyst to breakdown the gases caused by charging So they have to be charged at a slower rate and MUST not be overcharged PS some car batteries claim to be sealed but they are Not the same as a Gel battery and should not be used upside down !"
Answer 3: "Just be careful not to re-charge at a high rate as they can explode or lose their charge capacity. These are good for marine and motorcycle use. They can withstand a more physical beating as they are in a tougher, sealed casing. They use the same charger."
Based on this it seems on thesurface better to have a non-gel battery however I don't really have much knowledge on this topic.
