1 - 5 of 5 Posts
Ok, pull your heads out of the gutter! After installing my DIY BAK i moved my O2 sensor to a hand made plate. Well, I got home from a short put and decided to look under the tank using a flashlight and noticed the O2 sensor hanging down above the front cylinder, nutless. I had cut this nut out from the airbox housing and I won't be able to replace it with the same kind. Does anyone know the size of this nut?
Thanks in advance!
12 x 1.5 mm
1 - 5 of 5 Posts
