1 - 4 of 4 Posts
Just purchased 02' warrior the clutch needs to be bled i think, can anybody give me a run down on how to do it
Confused....
The warrior does no have a hydraulic clutch...
Maybe you should tell us what your symptoms are and we might be able to point you in the right direction...
More than likely you just need a clutch cable adjust...
And Welcome to the Forum!
Actually the Warrior has a cable clutch so bleeding is not an issue:} What are the symptoms that make you think something is wrong? If it's just simple adjusting.......try the search box up in the top right corner box and type in clutch adjustment. Lots o' info will appear. Or check back and we'll help.......
That's funny.......I had the window open 15 minutes answering another post and now I just repeat Siradude. Ah well, one more post I guess:}:}
1 - 4 of 4 Posts
