21 - 29 of 29 Posts
Discussion Starter #22
So I previously removed all the hoses and checked for obstruction and ware. All good and there are no pinch points. I swapped the electric plugs around to test each sensor. The sensor o have marked in the previous picture is the one tripping the codes, which the sensor itself isn't tied to a vacum hose, as it's the actual electrical connector for each IAP that's tied to a vacum hose. Unless there's something super obvious I'm over looking, which could totally be a possibility lol.
Discussion Starter #25
Your other option is to use the Warrior Diagnostics to validate a defective sensor :>)
My next course of action was going to be the diagnostics mode for the individual sensors.
Yep I'll check for sensor damage....didn't even think of that....duh.
Also, here's a Global Query from this site using: "Code 26" that is interesting!
The most common cause of this Code is Pilot's Error imho ;) ... no disrespect intended.
If you want to physically test the sensors with a DVOM then I suggest you read my early contribution here as the YFSM is NOT correct:
Discussion Starter #28
🤦‍♂️hahaha ok I'm a knuckle head!! I knew I was missing something completely obvious lol! Yes one of the Vacuum hoses seemed to be slipping off the sensor each time I put it back on and would fire the bike back up. Its loose on the sensor and must of been vibrating just off of the sensor while the bike fired up. One small tie wrap and problem solved! lol Thanks for working through this with me fellas, even though I'm a numpty haha! Lesson learned!
21 - 29 of 29 Posts
