1 - 20 of 32 Posts
What changes or improvements would you want made to the warrior if they were to bring it back? I know half of the fun is making it your own but was just curious to see what others thought besides the obvious of holding more fuel :p
21in front wheel and a 250 rear wheel...
And 6th gear tranny and 1900cc engine
Would do it for me...And of course more fuel capacity...
6th gear, 250 rear, 18" 180 front, bigger tank (4.5gal) supercharged 2000cc, with 220 rwhp
Kong taking it to the next level.....I like that :D
I will say that I have driven my friend's turbo busa and it will put your nuts in your throat in 3rd when the front wheel wants to come up.
That's a Sweet looking RAIDER...
It has everything that I hope that the warrior had...
It seems that was the new Version of the warrior and Yamaha got it right
How much fuel/range does the Raider have? More for the 2020 Warrior for sure. The Ivans re-flash stock would also be a must. Bigger is always better-tires HP/motor size.
Air cooled 120ci vtwin (dream) 140hp/150tq
250 rear for sure, maybe little wider front. Both 17” or 18”
Adjustable air ride standard
Ohlins inverted 43mm
Chain drive and to **** with the transfer case
A 5 gal tank would be great.
Can it have even more ground clearance but keep the same seat height? that would be cool.
Headlight bucket that accepts more aftermarket options.
550lbs wet!
Missiles
Yeah.
Hopped up Raider Engine.
Keep it low to the ground.
Sport Bike Wheels and Tires in more standard/common sizes
5 Gallon Tank with a good 1/2 Gallon Reserve
Don't design the tank to be a Ground Dent Magnet
1 Side Air Filter Assembly (vice 2 - the under the tank one was a pain) that DOES NOT stick out 8 inches
If there has to be an Air Induction System hide it in the bike and don't have it hanging off the side
LED everything
Horizontal exhaust that does not interfere with bags or passenger feet/legs (no swoopy bazookas)
1 - 20 of 32 Posts
