I was going to wait until it was a little warmer outside to install this kit, but I had the parts sitting around and I had nothing else to do today. So dressed in layers, fired up my propane sunflower heater in the garage and got to work. The sunflower heater didn't really heat the garage up too much, partly due to the fact that I left the side door open on the garage to allow fresh air to enter do I wouldn't die from carbon monoxide. The heater definetely did take the edge off though.
The install went very smooth other than the fact that I didn't have a 17mm wrench, so my turn signals are still loose. The instructions were very easy to understand. That was something that surprised me. Usually when you try to put anything remotely complicated together the instructions don't make sense at some point in the procedure.
I took my time, and just followed the directions step by step. It was so cold that at points I couldn't feel my fingers, so I had to take breaks to warm up my hands on the heater. I also installed a black radiantz LED license plate frame. That was probably the most complicated part, considering it involved soldering. I cut the connectors off the stock license plate light, and soldered them right onto the license plate frame wiring, so they can be unplugged ifI ever have a reason to remove it.
The kit looks great. That ugly plastic inner fender and plate light/reflector is gone. The kit also moves the turn signals in towards the fender for a sleeker appearence. The Radiantz license plate frame is awesome. I had to hook the battery up to see the lights. They are bright, and light up the entire plate. I will have no cop problems with this one.
Even if you arn't mechanically inclined, you can do this yourself. The instructions are that clear. All you need is a small metric socket set, and a couple screw drivers. Oh, and a 17mm open end wrench if you are going to keep your turn signals. I was going to post pictures tonight, but it's 4 degrees in the garage, and apparently thats cold enough to make the florecent lights in the garage not work. So as soon the temp rises enough for the lights to come on, I'll snap a couple photo's.
