Title says it. I’m looking for some stock clear front turn signal lenses if any of y’all wizards are holding. I’m sure I can find em no problem but figure I’d ask my buds first
🤙🏼 Turd
🤙🏼 Turd
Then you’ll most likely have issues with COD. LED’s, regardless of form, don’t provide the same analogue voltage drain that is needed to bleed residual voltage out of the system. LED’s are more digital so they’ll immediately switch off on power off instead of gradually fading like incandescents do.Correct. I wanna keep the running lignt and blinker feature. I just wanna upgrade to an LED over incandescent bulb. The only LEDs I can find are the 2 prong type. The incandescent one currently on my bike has 3. I remember reading about filing a prong down but I can’t recall which one 🤙🏽
Relay doesn’t fix it; only fast flash.hmmm well I did already install a relay so I do not have the fast flash. Rear are LED and front are incandescent.
