1 - 5 of 5 Posts
Hey Warrior guys and gals,
I pulled the trigger and sent out today my ECU.
After reading so many good reviews here, I’m looking forward to getting back on the bike.
Question for those who know.
I had set the CO, fuel mixture on the ECU a while back to rich’n things up a bit after adding a Vbak and free flowing exhaust.
Question,
Will Ivan’s tune accommodate my current mods and thus I won’t have the need to adjust cylinder 1 and 2 CO levels?
Ivan's will play okay with minor (1-or-2 point) CO1 CO2 ECU Bumps. I have messed around with it and can still go rich enough to smell it at idle. When riding above 1100~1300 rpm, CO1 CO2 are not relevant and I have not found any impact of an ECU Bump. Still, if you recorded the original settings you could set it back.
I had a slight bog off idle and richened up my ecu with the ecu bump and it took care of that. Now it runs super from 0- 100 per cent throttle with Ivan's flash. It didn't affect how the bike ran after the adjustment, it just took the bog out if that helps you out any.
Discussion Starter · #5 ·
An update,
I got my ECU back from Ivan yesterday and installed it.
I didn’t have time to ride it yet but did start the bike and so far so good.
Tomorrow I plan to upgrade both ignition coils with the Magna coils and Taylor wires ( Read a few posts on the forum on the install ), and hopefully all will go well.
1 - 5 of 5 Posts
