1 - 10 of 10 Posts
Hi all, just purchased an Ivan's Flashed ECU off of here and now I need a PCV map.
Hoping someone has one that matches my mods.....?
Churchkey's VBAK
AIS Blockoff
Graffeo Powerhouse Exaust (2 into 1)
UPDATE: I called Ivan and he emailed me a PCV file.
Thank you!
T
I tried running Ivan's map but for some reason I was running a bit rich. I ended up using a map that Steeda had done and that map was spot on.
Discussion Starter · #6 ·
Thanks man, I’ll check that one out!
I’m now running the one Ivan sent me, no issues as of yet. if anyone wants it let me know.
Discussion Starter · #7 ·
Thanks Stretch!
For the ECU, AND the files. :)
Yup there is a smorgasbord of maps where Hefty pointed to. Here is what I got for setting up and using Ivan's Flashed ECU. Change extension of the map to .DJM. Pretty sure the map is for dual pod intake and dual exhaust. Read it in PC5 software to be sure. If for some reason my changing the extension makes it no good text me your email and I'll send it that a way.
2006 Warrior
1 - 10 of 10 Posts
