@lwking86
Cool so you guarantee the fitment including freight because you do know the 2004+ seats sit inches further back and many here bumped into troubles with various brands having their passenger back pad not fitting above the passenger seat.
The side fender brackets bolted up fine. But the back pad could not be installed.
Maybe this builder moved the passenger pad higher up. The stock 04+ passenger seat is tall. Mustang and Corbin passenger seats are very tall. If this backrest pad clears those heights then lots of folks would jump-in.
02-03 seats mostly ended a little after the fender loop. Backrests were a bit further back. But the 04+ passenger seat is even further back, introducing the back pad interference trouble. Maybe on this unit they accommodated that. But just because a builder says something fits doesn't make it true as many here are painfully aware.
I hope it does fit!
Maybe you might post a measurement from the center of the fender mount bolt up in elevation to the bottom of the passenger back pad in order to save troubles?
You would be expected to provide a full refund and return freight if it doesn't fit. So we are not being a pita, we are trying to protect you and the buyer.
