CalWarrior said:Sorry, but I can't see the pics here at work. I am sure it looks good and will check it from home. What method did you use to lower? FNG, Tricky, lowering links, etc.? Did you upgrade your spring? I want to lower mine, but I have not picked a method yet. Thanks.
CalWarrior ... here's some olderthreads that might be of interest regarding alternate choices and specifics regardingthe PCS links:CalWarrior said:Sorry, but I can't see the pics here at work. I am sure it looks good and will check it from home. What method did you use to lower? FNG, Tricky, lowering links, etc.? Did you upgrade your spring? I want to lower mine, but I have not picked a method yet. Thanks.
Mike Panczyszyn said:Looks good, now you just need to get rid of that ugly mud flap at the back!
\NorCalWarrior said:I've got a set of PCS links that I have been waiting to install, how difficult was the install, I'd consider myself mechanically inclined but by no means am I a mechanic. Done all the bolt on work to my bike so far (bars/risers, exhaust, PCIII, and planning on doing my v-bak when it comes) Is this a fairly simple affair?
By the way bike looks great lowered, can't wait to get mine done.
Trick said:looks great! quick question, when you measured the before height, did you measure it straight up or on the kickstand? reason i ask is because i forgot to measure my height and i wanted to see how much i lowered it, if you can help me out that would be great!
trick
antitech1 said:Yeah, I forgot to measure mine before lowering too. I used a modified relay arm (flip and grind) but it might be too low for my tastes. My heel and pegsscrape too much.I plan in getting the adjustable Ram396. There is doubt in my mind thatlowering the bike makes it look way cool. Its not just a matter of removing the empty space between the fender and tire, it also changes the stance of the bike.
Thanks for posting pics... but all I saw was a swingarm sticker. shame shame
cordxxx said:\NorCalWarrior said:I've got a set of PCS links that I have been waiting to install, how difficult was the install, I'd consider myself mechanically inclined but by no means am I a mechanic. Done all the bolt on work to my bike so far (bars/risers, exhaust, PCIII, and planning on doing my v-bak when it comes) Is this a fairly simple affair?
GOOD NEWS!! It's not that bad lol. Mainly you are going to need some kind of lift because the hardest part is finding the right position (have to move the rear tire up and down) to get the suspension back in the bike. Anyways here you go:
1) Liftthe bike...make sure you put the lift far enough forward to be able to get to the rear suspension...remember it's gotto come out.
2)Get the horn outof the way then use a 17mm to remove2 bolts that hold the assembly in place.
3) I had to jack the bike up and down a little here to find the right height to be able toget the suspension out. It'sa little tight just be patient and trynot to cuss as much as I did.
4)Take the factory arms/links off and install the new ones. Probably wouldn't bea bad idea to grease everything since it's already apart.
5) Put itback in...helps to have another person at this point to raise and lower the rear tire by hand so you canfind the right positionfor it to slide back into place.
6) Make sure everything's tight and enjoy.
Any other ?'s PM me.
