Hey Guys. Most of you don't know me as it's been about 11 years since I've been around. Spent a good deal of time on hear from 2005-2009 and benefitted greatly from all the knowledge as I built my Warrior. It was a bittersweet day in 2009 when it was traded for my first Harley, but the Harley was better fitted for the longer distance rides I was doing. Fast forward to now and I wanted a second bike and found a really good deal on a 2002 Warrior. So I purchased it and came back here as I figured I couldn't leave well enough alone for long. This time is a bit different as my first Warrior was brand new and I made all the modifications to it. This one has been hacked on quite a bit and I've spent the last week just getting things that should work, working. I also had to fab a cheap license plate bracket as the previous owner just bent his plate and metal screwed it to the inside fender.
Some of the modifications I am sure of is the front end has been lowered an inch. I can even verify that by the nice dimple in the front fender. There are LED front blinkers wrapped around the fork tubes and some cheap LED strips glued to the tail light that I just removed. And the whole rear license plate/blinker mount had been cut away. It also has a power commander and Vance and Hines Big Shots, although I have no idea what tune is in it yet. Now that I have all the lights working and a place to put my tag, the next project will be to install a baron's AIS block off kit and try and reduce all the backfiring on deceleration.
that's about it. Wanted to say hi and let you know what I'm up to in case you have any suggestions for the next project.
