1 - 1 of 1 Posts
Hi guys,
I just bought a pair of mirrors with LED turn signals. I am trying to replace the stock turn signals with these ones. I took off the stock turn signals and the bike is now making poping noises + the lights blink too fast. I know these things can be solved with a load equalizer, but I also want to have them function as runnning lights.
I found an eclipse module on the custom dynamics web page (http://www.customdynamics.com/eclipze_module.htm) that converts turn signals into running lights + turn signals.
They also have this Standard DOT Flasher unit (http://www.customdynamics.com/trick_flasher.htm) that replaces the stock flasher relay so if I buy this insted of the load equalizer will it fix the fast flash rate and also get rid of the noises coming from the bike when I turn it off?
I was looking into getting the Universal 7.5 Ohm Metric Turn Signal Load Equalizer (http://www.customdynamics.com/loadequalizer.htm#Universal Turn Signal) would this be a good choice?
So what should I get:
1. The eclipse module with the load equalizer
- with this option does it matter if I put the load equalizer before I attach the eclipse module or after I attach it?
2. The eclipse module with the Standard DOT Flasher relay
or
3. The eclipse module, Standard DOT Flasher relay and equalizer?
Thanks for the help!
1 - 1 of 1 Posts
