21 - 40 of 76 Posts
Argh. Question on this install.
There's a vacuum connector on the fuel pressure regulator.
But I can't figure out what (if anything) gets connected to it and there's nothing mentioned in the instructions.
Lil help?
Discussion Starter #27
Is there a parts list on here or a sticky
-Two feet minimum of 8AN hose, I recommend more for a little margin of error when you cut.
-Jiffy-Tite 31608 (J) and 32608 (J) valved quick-disconnects with Viton seals. Adding J to the product number specifies all-black, otherwise they come in a black/gold finish.
-Two hose clamps for the tank fuel line. The hose is approximately 5/8" OD.
-5/16" FI rated fuel hose, to relocate the fuel pressure regulator.
-Four 5/16" FI rated hose clamps.
-Heat shrink to prevent any fraying of the cut braided hose ends. (Optional, but really nice if you used stainless braided line. Nylon braided line you can "melt" the ends).
-Two M5 x .8 nuts for the FPR.
-I highly recommend an 8AN assembly wrench or two, so you don't mar the fittings.
Discussion Starter #28
Note that you also might need to slightly flare the ends of the 8AN line, to make it easier to fit over the fuel tank nipples. I built a forming tool by cutting the threads off a long 1/2" bolt, and rounding the unthreaded portion. Held the tool in a vise, applied heat and a little engine oil while working the hose about 2" down the bolt shank. Made assembly much easier.
Finally got around to doing this. Nice mod, simple but took some effort to figure out locations and muscling the new lines into place. I didn't make the engine bracket any narrower but I'm happy with the result. Love that my knees can hug the tank on both sides. Thanks, Jason.
Discussion Starter #31
Looks awesome. Like you said, it's nice to not have that cover hitting your knee anymore huh?
Ok all here goes:
I followed the direction that Jason has already posted - with a few minor adjustments.
So the only difference on my install is:
1) I used the factory fuel line from the AUX tank to the FPR, I just cut it down to the length that I needed. I used the 12" piece supplied with the kit to go from the FPR to the fuel injector, again I just cut it down to the length that I needed.
2) I reused the factory "CRIMP" fuel line clamps on everything except the FPR to the fuel injectors. I also installed the "SPRING" thingy on that section of the hose as Jason suggested.
Can you possibly upload the pics that photobucket moved?
I'm going to be buying the parts from this list and doing this mod soon! How much of the 5/16" fuel line will I need to relocate the pressure regulator?
Sent from my SM-G935V using Tapatalk
Discussion Starter #40
If I remember right, it only required about 12 inches. Make sure your fuel line is rated for high pressure though!
21 - 40 of 76 Posts
