1 - 6 of 6 Posts
Hey everybody.. just did the VBAK, coil relocator plate and some other odds and ends. I was just wondering what to do with all the "stuff" on the left side so I can get rid of that fake air scoop. I have no problem with hacking the motor mount, but not sure what to do with the Quick disconnect and fuel regulator. I have seen some pics with that stuff moved.... but don't know where it was moved to. Any help / advise / links / dirty jokes / hot lady pics would be appreciated. Thanks.
Discussion Starter · #3 ·
Thanks for the pics link, but where does that stuff go?..Under the tank wherever it can fit?
I bought a piece of 1/2" fuel line to run from the tank to the dry break, it was longer than the stock piece so that I could set the dry break right on top of the rear cylinder. I also had to run another piece from the fuel pressure regulator to the injectors. It was all pretty easy. I cut off quite a bit of my mount and used a grinder to give a half moon contour so that it could not be seen from the rear.
My pics are on flickr.com/dicknezat
1 - 6 of 6 Posts
