1 - 4 of 4 Posts
I am going to clean-up the left side and need to replace the quick connect that you unhook when you remove the tank. The two hoses that go into the stock quick disconnects appear to be about 7/16 ID. What do you use for a quick disconnect to fit this size hose or have people just repalced the hose with a different size hose?
if you are not talkng about the big fat fuel lines but the quick disconnect that will only be about 6 inches long, the ID is 5/16".....actually am holding a pice in my hand as i type this.....
I am talking about the grey line with the spring around it that conncects to the disconnect that you have to undo to remove the fuel tank. It is the one on the motormount.
I use 3/8" fuel injection rated fuel line. Plenty big for a gravity feed to your secondary and fuel pump.
1 - 4 of 4 Posts
