The linear control valve (LCV) is sort of like a choke but for fuel injected engines.
The linear control valve supplies air to the throttle bodies when starting or during engine warm up and causes higher idle Rpm's.
The intake air volume determines the basic injection duration. As the intake air increases through the linear control valve, the intake air volume corrects the basic injection duration.
The correction volume changes according to the position of the valve at starting and when the valve position changes to accommodate the engine temperature and engine oil temperature as the intake air volume increases.
When the engine oil temperature reaches 80 °C (176 °F) or higher, the linear control valve fully closes to stop the air volume from increasing and control returns to basic injection control.
Now, this part can cause some issues if the pintle seat (see pic) or the tapered pintle (see pic) develops build up to prevent the valve to fully close and let surfaces to seal.
It can also possibly develop a vac leak between the O-ring on the valve motor and the passage housing(see pic).
The motor can also fail all together and not function or properly function.
Either way these can cause a vac leak that can cause some issues you will chase and chase and may not find.
Some symptoms are Loss in power, Poor throttle responce, Excessive popping, Chugging lower Rpm's, Stumbling with throttle, Erratic idle, dying.
A way to quickly eliminate the LCV being the issue to vac leak symptoms is to remove the 2 smaller hoses off the LCV and plug them good making sure no air gets past. Make sure you see no cracks in the 2 hoses going to your throttle bodies before running the motor. (See pic)
If your symptoms go away or reduce you have a few options.
If you do not get a diag code-
1. Leave the LCV blocked off as testing by plugging the 2 hoses from the LCV.
2. Pull the 2 hoses off the throttle bodies and cap the nipples(with time the caps can crack and you'll develop a vac leak. (See pic)
If you have a vac leak issue through the LCV go to the cleaning process or block/remove the LCV.
NOTE FOR THE 2 OPTIONS ABOVE.(For testing and permanent)
You will now have to give some throttle while starting especially in colder weather and you'll have to hold the throttle to warm the engine up to keep it running.
Keep in mind that if you keep thw LCV this way as of Blocked, Capped and you go and try to sell your bike this new starting prosses may sway potential buyers away as it will look like the bike has issues.
To clean the LCV-
1. Set the hoses back on the LCV as normal set up and spray throttle body cleaner or Spray Seafoam through the Bigger inlet hose to the LCV while first start/starting for a few seconds. Have The bike run for a 5-10 seconds after you stop spraying. The valve closes quick so you will have to repeat that starting/spraying process over and over. The engine may be hard to run at first as that's what the cleaner will do so give it some throttle to keep it running. This may/may not help.
2. Remove the LCV and clean by hand with throttle body cleaner. Make sure you clean The pintle and pintle seat.
The O-ring may need a bit of silicon to help seal a vac leak so apply a thin coat and let dry while assembled.(may not be necessary)
If this cleaning does not fix the LCV vac leak the valve motor may have failed.
You can test the LCV pintle for movement (I WILL ADD THE INFO LATER AS I WANT TO TEST THE ON BIKE TEST FIRST)
((If anyone has anything to add or any input feel free to mention it and I'll adjust the posting))
