  • Voting Now Open for the Warrior of the Quarter Challenge! Vote HERE
1 - 7 of 7 Posts
· Registered
I just picked up my 05 RSW about two weeks ago, and I have been doing some modifications since. Lots of various cleanups from around the forums, and it's been very helpful. However, I've been trying to find some of these VBAK plates as I want to continue cleaning the bike up, but I cannot find any since Churchkeys seems to be out, and same for Akitadog. The Baron's VBAK (Whole Kit) seems unnecessary to purchase as my bike seems to have different filters compared to that kit, and I'm unsure of what it has specifically. If anyone happens to have any sort of these relocation plates and can send me a picture of the plate w/ measurements so I can make my own, or has a working link to an alternative coil clean up, that would help me a lot. I will be making another post to show my bike off, I've taken inspiration from several example bikes, forum posts, etc.
· Premium Member
Check here In the link below as it has some drawings and spend a little time searching the forum as there is a wealth of knowledge stored here....
· Registered
Thanks guys, so far that first response helped, I think I'll just be making my own bracket starting this weekend, it actually seems fairly easy to make and I have a buddy who can help me fab things up. So far I'm absolutely loving my bike, and I'll get around to a big picture/video post this weekend as I have a couple more things to fix, as of now I'm working out a fix for the click of death (trying to find a post I seen regarding the use of a relay instead of a halogen bulb), an oil change tomorrow, and I'm also needing to realign my headlight
· Registered
Hi there Parceval, when doing your oil change make sure that you read up and follow the correct procedure for doing this as it isn't as straight forward as you would think. There is lots of information on this site that will show the correct way to do it. Hope you this helps. Frec 🇬🇧
· [Retired Admin-SuperMod]
@Parceval welcome aboard! Before you decide on which undertank relocation plate to use, you'll need to know if your ignition coils are stock or if they are dyna DC2-1 coils (or similar) which need a slightly larger hole. You also need to know if your existing intake air filters are round or cone, AND if they fit directly to the intakes (BAK) or if they have a long tube velocity stack (VBAK). Churchkey's hard-to-find stainless kit is the only professional velocity stack (VBAK) kit out there. There are also some DIY kits out there but those tend to be harder to maintain and appear cluttered. I HIGHLY recommend begging Churchkey for a set of velocity stack tubes and intake end attachment. You can polish the stainless yourself. And you can get cone filters if needed. Although the K&N brand RC1290's are discontinued, some are still out there on shelves. Plus there are other brands out there now.
So in a large nutshell, be sure the plate you get will accommodate DC2-1 Dyna ignition coils so if you need to change coils in the future it's good to go. Also give attention to the intake air filter's size and shape and fitment arrangement (BAK or VBAK) so everything fits under the top fuel tank.
The only relocation plates that meet all these parameters are the AKITADOG BAK and VBAK plates for DYNA coils. He also made a plate for stock coils in the earlier days, so you need to know which you are getting if buying used. These AKITADOG plates are the ones you are already seeing in our Documentation forum. BTW his Dyna coil plate fits stock coils too.
This all sounds complicated. But there's tons of info here including pictures of different installs members have done over the years. And the CHURCHKEY VBAK INSTALL INSTRUCTIONS are posted around here someplace, they actually help no matter what variation you get. Also see REDHORSE:
A handy tip to be aware of in advance: air sensor electric plugs and matching vacuum hoses:
One other handy tip:
You might need to loosen the main wiring harness under the fuel tank where it follows the top right side frame tube back toward the rider seat latch plate. The section of harness sometimes needs to be slid slightly aside to clear that air filter. It's going to be obvious if you have that arrangement, and it's a ten second fix if you do need it slid.
Hope this helps while you work through it. Again, it sounds difficult but knowing about these things in advance you'll find everything goes well.
· Registered
Discussion Starter · #7 ·
@arizonawarrior thank you for all that info! I was especially looking at changing the coils out one day as well, so knowing exactly what I need is perfect. As for a mount, I think the easiest thing for me will be custom fabbing one because the intakes I have are straight on the throttle bodies like a BAK like you explained, I don’t have any tubes that lead into those. I’ll be sure to check the harness when I’m under the tank again, I’m going to be taking it off in order to get this dry break modification done. I’m pretty sure the way I plan to get this all done has already been documented, I’m following a tutorial by Brian for the dry break.
I think I will go ahead and document the process approach all of this with. The Way my bike is coming along is quite a good change from when I got it and it’s making me quite happy.
1 - 7 of 7 Posts
