1 - 4 of 4 Posts
Hi i just got my warrior bout 2 mths ago and already customizing already put 5in control exstentions and barons drag bars and now im looking 4 sum lowering links jus let me know
First, welcome aboard!
Here's a bunch of links from the Popular Mods post:
Suspension - Air Ride: http://rswarrior.com/forums/p/16834/274689.aspx
Suspension - Air Ride: http://rswarrior.com/forums/p/26983/388623.aspx
Suspension - Air Ride - PSI Gauge: http://rswarrior.com/forums/t/116567.aspx
Suspension - Tricky Air - Replace Air Tube: http://rswarrior.com/forums/t/119930.aspx
Suspension - Tricky Air - Tire Life: http://rswarrior.com/forums/t/113191.aspx
Suspension - Spring - Rear - Stiffer: http://www.ground-control-store.com/products/description.php/II=367
Suspension - Spring - Rear - Eibach 1000: http://rswarrior.com/forums/t/29316.aspx
Suspension - Spring - Rear - Raising Methods: http://rswarrior.com/forums/t/106308.aspx
Suspension - Spring - Rear - Raising Methods: http://rswarrior.com/forums/t/106293.aspx
Suspension - Spring - Rear - Lowering Links: http://rswarrior.com/forums/t/29176.aspx
Suspension - Spring - Rear - Lowering Links: http://rswarrior.com/forums/t/29316.aspx
Suspension - Spring - Rear - Lowering Links: http://rswarrior.com/forums/t/28556.aspx
Suspension - Spring - Rear - Lowering Links: http://rswarrior.com/forums/t/108807.aspx
Suspension - Spring - Rear - Lowering Links: http://rswarrior.com/forums/t/28528.aspx
Suspension - Spring - Rear - Lowering Links: http://rswarrior.com/forums/t/26728.aspx
Suspension - Spring - Rear - Lowering Links Topics in PDF form: Send your email address to:
1. Ram396: http://rswarrior.com/forums/AddPost.aspx?ForumID=0&UserId=11485
2. Dram06warrior: http://rswarrior.com/forums/AddPost.aspx?ForumID=0&UserId=13387
3. ArizonaWarrior: http://rswarrior.com/forums/AddPost.aspx?ForumID=0&UserId=7601
Suspension - Spring - Rear - Lowering Methods: http://rswarrior.com/forums/t/109605.aspx
Suspension - Rear - Flip N Grind:
1. (educate yourself search for topics, also this is not reversible like lowering links)
2. http://rswarrior.com/forums/t/119346.aspx
3. http://video.google.com/videoplay?docid=-6489500324050279388&q=%22Road+Star+Warrior+Flip-n-Grind%22+playable%3Atrue
I have a set of PCS Lowering links if interested. I installed them but was too low with phat tire kit. let me know if youd be interested
1 - 4 of 4 Posts
