Hey my friends. I am thinking of lowering my 06 Warrior without breaking the bank. My question is how much does it affect the ride if I use the Ebay kit that just brings down the bike? Anyone have experience with this?
Thank you very much! great infoI would get the Baron's kit as it is all steel. That kit uses stainless and aluminum which are terrible together and cause galling. Galling is when the different metals are used together and with force, friction & weather they will usually fuse together. Here is the Baron's and I do agree that this is the best way to lower the Warrior
Baron Rear Shock Drop Bracket Lowering Kit 1"/2" #BA-7500-20 fits Yamaha | eBay
Rear Shock Drop Bracket Lowering Kit 1"/2". This item fits the following applications Country of Origin. Made in the U.S.A. Product Details.www.ebay.com
Good point. I know there is some sacrifice just wondered if it was night and day difference or not that bad. I am old, dont want to bottom out every bump lolAs far as the ride, it essentially puts the shock into a shallower portion of the rising rate of the linkage. So you will also to a certain extent put the shock at less of a mechanical advantage which will have the effect of softening the spring and damping.
Thanks Churchkey!Just lowering the rear = more difficult turn in, if no twisties & just wanting to look cool go for it.
Front: Slide the tubes up in the trees an inch BUT if you still have the stock brake block it will hit the fender. Black R1 forks are 7/8 shorter than Warrior tubes.
thank you!!!Good thing about this lowering kit is that just a little goes a long way.
After you lower it you can play with the shock settings and tighten it up a bit.
