You don't have a gallery page so I can't check but didn't you buy a 2002 model year Titanium bike?
Anyway, as long as you have the stock rear tire size, your fixed links will probably keep the tire off the fender no problem. If you do any 2-up riding and your passenger's weight plus your weight exceeds spring capacity then you will probably bottom out and maybe tear up some wiring. Some guys add the Eibach 1,000 pound spring and it helps depending on weights involved.
Oh, itsodd that someone told you to avoid the adjustable links, unless they haven't seen the Warrior-specific adjustable links? One of our members, Ram396, puts together a set with more capacity than possibly needed. Just curious is all.
backspa said:
Finally got lowering kit, any tips or gotchas i should aware of?
