Ok I hope this isn't major, and can become a easy fix but I don't know where to start.
Well here's the problem my Warrior feels like it "slipping" when you twist the throttle. It makes a clunk,clunk,clunk sound when you get on it. It doesn't matter which gear you are in when you get on the throttle. It stutters but it's not coming from the engine. It's a trans/clutch problem. It only does it if you twist the throttle. I just drove it 749 miles and it did it the whole time. If you go though the gears slow you don't have a problem but if try to get on normally it sounds like it's going to explode. At first I thought the belt might be to tight but doing the Warrior to Warrior feel with another bike it felt the same. I've had a problem with my clutch/cable since I've had the bike but the 3 times the dealer has not came up with a problem. I know there is and now there is more of a problem. It's still under warranty but I'd rather not take it to the dealer if I didn't have too.
If you have any questions or remedies let me know. It's hard to explain. the feel and sound. I'm afraid to ride it now. I don't want a trans lock up.
